Hey all,
We identified some line geometries that need to have the order of their vertices replaced to utilize arrowhead symbology to visualize flow. We were successfully bale to piece together a script that worked on a feature class in a file gdb, but when trying to execute on our enterprise gdb it did not work and prompted the error message:
Polyline - Reverse Geometry
Parameters
Input Feature Class SW Assets\dPipe
Messages
Start Time: Thursday, September 12, 2024 10:16:00 AM
File "<>\PublicWorksTools.atbx\PolylineReverseGeometry.tool\tool.script.execute.py", line 60, in <module>
File "<>\PublicWorksTools.atbx\PolylineReverseGeometry.tool\tool.script.execute.py", line 17, in reverse_line_geometry
RuntimeError: cannot open workspace
Failed script Polyline - Reverse Geometry...
Failed to execute (PolylineReverseGeometry).
Failed at Thursday, September 12, 2024 10:16:55 AM (Elapsed Time: 54.98 seconds)
Script documentation
- Tool parameters are accessed using arcpy.GetParameter() or
arcpy.GetParameterAsText()
- Update derived parameter values using arcpy.SetParameter() or
arcpy.SetParameterAsText()
import arcpy
def reverse_line_geometry(input_feature_class):
Reverses the direction of line geometries for selected records in the input feature class.
:param input_feature_class: Path to the input line feature class
# Start an edit session
workspace = arcpy.env.workspace
edit = arcpy.da.Editor(workspace)
edit.startEditing(False, True)
edit.startOperation()
try:
# Use an update cursor to iterate through selected features
with arcpy.da.UpdateCursor(input_feature_class, ["SHAPE@"]) as cursor:
for row in cursor:
# Get the current geometry
geometry = row[0]
# Reverse the order of points in each part of the polyline
reversed_parts = []
for part in geometry:
reversed_parts.append(arcpy.Array(part[::-1]))
# Create a new polyline with the reversed parts
reversed_geometry = arcpy.Polyline(arcpy.Array(reversed_parts))
# Update the row with the reversed geometry
row[0] = reversed_geometry
cursor.updateRow(row)
# Stop the edit operation
edit.stopOperation()
print("Successfully reversed the direction of selected line geometries.")
except Exception as e:
# Abort the edit operation in case of an error
edit.abortOperation()
print(f"An error occurred: {e}")
finally:
# Stop the edit session
edit.stopEditing(True)
if __name__ == "__main__":
# Retrieve parameters from the tool
input_feature_class = arcpy.GetParameterAsText(0)
# Set the workspace environment to the appropriate geodatabase
arcpy.env.workspace = arcpy.Describe(input_feature_class).path
# Call the function to reverse the line geometry
Thanks in advance for any insight into how to correct this issue.
