Robert (and others), if you add your Web Mapping Application to arcgis.com and mark them as below, then they should also show up at http://help.arcgis.com/en/webapps/flexviewer/gallery.html Purpose: ConfigurableAPI: FlexTags: flexviewer2
Why is it called a "Code Gallery" if there isn't actual code available? Is there going to be something equivalent to the old code gallery where you could sort, rate, comment, and download actual code?
Joshua, some entries have code available (for example the source code for the Flex Viewer). It is up to each developer if they want to include the source code (or not), or if they want to provide a working link to it (or not).It is similar to the old code gallery in that you can sort, rate, comment and download actual code (if it was uploaded). Click on the "Details" below the thumbnail and you should be able rate, comment, and download the code (if available).We decided to keep the name as "Code Gallery" because "Code and Application Gallery" seemed a bit long 🙂
Great new look, Robert. However, I am getting a Flash error when opening your custom header version.
Ken, Thanks for the headsup I was able to get this error in IE 7 when I got home on a slower internet connection...? IE 7 must be do things in a strange order as the offending line of code what just a simple line telling the graphicsLayer to be visible. Hum... Anyway I have put some checks in there now to be sure the graphicsLayer for all my widgets that use graphicsLayers are not null before I try to use them.
Don, I don't think it was to hard. The big thing is if you are migrating your custom widgets and want to use mainly Spark then you have to get rid of your repeaters and switch to data groups, which force you to develop item renderers for the datagroup. I went ahead and took the time to migrate all my widgets to the new Spark components all except for my TOC widget. I had to fix serveral things in the Beta Viewer, like data messaging, the infopopupwidget, lots of css, issues with the tooltips and header widgets appearing below docked widgets, etc.There no time like to present to dive in as this is the direction everyone needs to go.
Tony, Both the circle and the exporting and importing graphics are available in this widget I created http://resources.esri.com/arcgisserver/apis/flex/index.cfm?fa=codeGalleryDetails&scriptID=16634
