Verry frustrating,
I'm with Pro 3.3. Since arcmap with data driven page and now with mapseries, I use "Geoprocessing - Tiled labels to annotation".
Before, in arcmap, the only problem was the processing forget to put the TiledID in some pages annotation s.
At first, until 3x, the processing iwas a relief, working correctly except ESRi introduce the automatic removing of labeling.
Normal y, I have a map with groups of label to convert in annotation. To remove the load, I have 4 groups where à check an uncheck (and saving after) before doing processing.
If I'm going with "Convert - All layers". The tables are empty in some layers (WYSINWYG). If I select only one layer at a time, the table have the data completed. But now, I can't find the problem. I check for any problems in the summary, validate that each layer is in mode label.
Any idea?
