I had put in a ticket for an issue with the selection tool in the map widget in Experience Builder in June of 2022. When using the selection tool, only a certain number of features would be selected (these were coming from an ArcGIS Server) even if a large freehand selection was drawn. For example, I may draw a giant polygon around a neighborhood to select all of the tree points, which there could be serveral hundred, but it would consistently only select up to 100 each time. A bug was logged for this - BUG-000143500 however it still says this is an open bug that is under consideration even though I believe it was fixed. Can anyone, specifically anyone from ESRI, confirm that this has been corrected?
