I am trying to run a deep learning algorithm to detect shipwrecks using bathymetry data. I am using the Detect Shipwrecks example project template (https://www.arcgis.com/home/item.html?id=072a6af548ee4ad9a784881270b99266). I am using the Shipwreck Detection model (https://www.arcgis.com/home/item.html?id=28755e99bbde42508f22b957681a70e2). The example BAG data can be found here: (https://www.ngdc.noaa.gov/nos/H12001-H14000/H12891.html).
I follow the instructuions for running the example Shipwreck Detection ArcGIS project, but am encountering the following error when running DetectObjectsUsingDeepLearning():
File "C:\Mac\Home\Documents\ArcGIS\Projects\ShipwreckProjectTest\detectshipwrecks.py", line 99, in <module>
raise e
File "C:\Mac\Home\Documents\ArcGIS\Projects\ShipwreckProjectTest\detectshipwrecks.py", line 89, in <module>
arcpy.ia.DetectObjectsUsingDeepLearning(tfile,
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\Functions.py", line 4127, in DetectObjectsUsingDeepLearning
return Wrapper(
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sa\Utils.py", line 45, in swapper
result = wrapper(*args, **kwargs)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\ia\Functions.py", line 4115, in Wrapper
result = arcpy.gp.DetectObjectsUsingDeepLearning_ia(
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: A raster error has occurred. The messages that follow will provide more detail.
Failed to execute (DetectObjectsUsingDeepLearning).
Failed script Shipwreck Detection from Bathymetric data...
Failed to execute (detectshipwrecks).
Any help would be appreciated. Thanks!
