I have a set of points. For each point, I want the values from a raster within a buffer radius around the point. The radius of the buffer can vary. Once I have these values, I compare them to a value from the point attributes. I'm checking to see if at least one value from the raster is +/- 1.0 from the point's value. I have figured out how to do this with ArcPy, however I have thousands of points and it takes about 30 seconds to run just 10 points. Is there a faster way to do this?
I'm running Python 3.11:
with arcpy.da.UpdateCursor(TestPts, fields, wclause) as cursor:
for row in cursor:
# Create a buffer polygon geometry around this point
geom = row[0]
buff = geom.buffer(thisbuffdist)
# Set the extent to just the buffer polygon
arcpy.env.extent = buff.extent
# Extract raster cells within the buffer
OutRasEBM = ExtractByMask(Ras, buff, 'INSIDE')
# Convert extracted Raster to numpy array
arr = arcpy.RasterToNumPyArray(OutRasEBM)
# Clear buff and OutRasEBM from memory
del buff, OutRasEBM
# Find if a value in the array is within 1 foot of pointvalue
pointvalue = row[1]
diffarr = arr - pointvalue
for rw in diffarr:
for x in rw:
if x > -1.0 and x < 1.0:
row[2] = 'P'
break
cursor.updateRow(row)
