Is it possible to show the most recent data point using the dynamic text widget?
TIA!
Hi MFazio,
Text Widget doesn't support this now. Once we have the solution, I will let you know.
Thank you.
Hi @MFazio ,
The text widget supports Arcade expression in the June 2025 AGOL release.
You can use a similar script as the following:
var fs = $dataSources["dataSource_id"].layer; var sorted = OrderBy(fs, "date_field DESC"); var fpt = First(sorted); return fpt.date_field;
Shengdi
