Hello everyone,
I'm experiencing an unusual issue with an Enterprise Geodatabase hosted on SQL Server. Specifically, I'm unable to delete a feature class within a dataset from ArcGIS Pro. When I attempt to delete the feature class, the process appears to complete successfully without any errors. However, after refreshing the feature dataset, the feature class still appears intact. Furthermore, I can add it back to the map without encountering any issues, and the data remains unaffected.
Some other information
- I noticed that this behavior only happen when the data owner is not dbo (ex: if the feature class is dataowner.building, then I cannot delete it). On the other hand I can delete a feature class in a feature dataset when it is owned by dbo (ex: if the feature class name is dbo.building, then I can delete it)
- Regarding permissions, the schema owner (dataowner) has the permissions listed in the documentation.
- I can reproduce the behavior in multiple geodatabases. Every new database I create has the same behavior.
- I have tried creating a trace using SQL Server profiler and tried collecting different type of information with no luck. I used a standard trace template and a custom one. No errors have been detected.
- I have tried also extended events and no errors also noticed.
- I can delete the table (feature class) in SQL Server from SSMS but I know that this is a wrong action as the tables have another dependencies and the table still exist in the geodatabase. I have just mentioned this piece of information just to confirm that the case is not related to permissions.
- I cannot delete the table from ArcGIS Pro with a sysadmin user.
- I cannot delete the table from ArcGIS Pro as the schema owner even if I assigned the schema owner the sysadmin role
Environment information
- The geodatabase is in DBO owned schema
- User data is in dataowner schema
- SQL Server authentication is (Windows Authentication)
- ArcGIS Pro Version is 3.1.3
- SQL Server version is 15.0.4345.5
- SQL Server Edition: Enterprise
- Operating System: Windows Server 2022
Has anyone else encountered this problem or have any suggestions on how to resolve it?
Thank you!
