Pro currently does not use standard behaviour when clicking in a setting text box.
Current behaviour:Click in setting field > Double Click selects digits in front or behind decimal point, or units. No amount of clicking can select all.Text settings after a double click in various locations in the text box as example:
Expected behaviour:Double Click on field to select all in the field > type values to set new parameters.
Also see this idea:https://community.esri.com/t5/arcgis-pro-ideas/when-using-tab-to-jump-between-properties-select/idi-p/1493502/jump-to/first-unread-message
Sign in to post, follow content, and more. New here? Register for free.
