In the Select By Attributes window:
Could an option could be added to the operator picklist: "is duplicate"?
I'm aware of the Find Identical tool. That tool exports a new dataset. I want to dynamically select in my existing dataset.
I think this is impossible to implement. Currently the Select Layer By Attribute tool is a SQL clause builder, and the available conditions in the drop down all map to standard SQL operators that nearly every data provider supports:
When you go outside the common SQL operators above, the implementation of a given operator starts to vary widely across data provider, to the point of not being supported at all. Additionally, all of the common SQL operators above operate on a given row where finding duplicates requires looking beyond a given row to an entire dataset itself.
There are numerous ways to find duplicates via SQL, and someone can always write custom SQL in Select By Attributes, but that requires knowing what the underlying data provider supports for SQL.
I understand the convenience factor of having such an option, but I just don't see it implementable without completely refactoring the tool.
@JoshuaBixby Fair points.
For what it's worth, I was thinking of something generic like this that would be supported by all databases:
asset_id in (select asset_id from sidewalks group by asset_id having count(*) > 1)
However, I had forgotten that FGDB SQL is limited. "ERROR 000358: Invalid expression"
Related: Attribute Table — Select duplicates button (including FGDBs)
Sign in to post, follow content, and more. New here? Register for free.
