Hi All,
I am Looking for some help and advice. I am working on this trail report for our parks department. A piece of information that they want would in which national forest is this trail in. Is there a way to use the map component in the survey to pull out that answer for this report?
Also, I want all the data associated with a certain crew to display in the table I have below. How can I have all the attributes for the table filled out from multiple survey results? For calculating totals is this a similar syntax to survey 123 connect for calculating sums for totals whatever the fields fill out?
Thank you, Megan
