There are common fields between the five tables that I need to average but not in the attribute table that I need the calculated value to go.I'm thinking there might be a way to use update cursor to do this?
Rachel,Is there a common attribute between all of the tables?If so you could join all of the tables together and use the calculate field tool and then remove the join.
