I have a python tool with the following structure:
- Script folder
- main_script.py (the script that the GP tool points to)
- module.py
- module_helper.py
The main_script.py imports module.py, and module.py imports module_helper.py. Importantly, main_script.py does not directly import module_helper.py.
When I publish via Pro's Share as Web Tool, the main_script.py and module.py will upload, but module_helper.py will not. Based on testing it seems like module_helper.py is not uploading because it is not directly called by the "main" script that the GP tool points to.
Is there a way to get all scripts in the folder to upload, even if not directly called by the main_script?
Note - There are clunky workarounds: One is to manually copy over module_helper.py. But that's a cumbersome step, especially when I have to do it on a frequent basis. Another option is I could just import them into the main script even if I don't use them, which would ensure they upload, but it's poor practice to import modules you don't use (wastes memory and has potential to create confusion later).
PS - I feel like @DanPatterson or @Luke_Pinner might have some useful insights on this.
