pntGeom = arcpy.PointGeometry(arcpy.Point(2000, 2000)) #substitute your centroid x/y coordinates circleGeom = pntGeom.buffer(100) #substitute the distance from your circles verticies to the centroid arcpy.CopyFeatures_management(circleGeom, r"C:\temp\test.gdb\test) # copying to a GDB will preserve the "true curve" geometry arcpy.CopyFeatures_management(circleGeom, r"C:\temp\test.shp) # copying to a .shp will force densification
import math, arcpy def circle_poly(x,y,r): for i in range(100): ang = float(i)/100 * math.pi * 2 yield (x + r * math.cos(ang), y + r * math.sin(ang) ) pointArray = arcpy.Array() for (x,y) in circle_poly(-121.4543,43.972,100): pointArray.add(arcpy.Point(x,y)) circlePolygon = arcpy.Polygon(pointArray, arcpy.SpatialReference(4326)) outFC = arcpy.CreateFeatureclass_management("in_memory","circle","POLYGON") arcpy.DefineProjection_management(outFC, arcpy.SpatialReference(4326)) cursor = arcpy.da.InsertCursor(outFC, ["SHAPE@"]) cursor.insertRow([circlePolygon]) del cursor del circlePolygon del pointArray
is it possible to read that kind of information from a 'true curve' circle using a search cursor
