Some points were gathered in an incorrect survey. Is there a way to move a point from one survey to another without loosing the data?
Hi @JoeLoverich
Thanks for your question. There may be an easier way to do this so happy for anyone else to jump in but here's how I would do this:
1. Create a view layer from the feature layer of the incorrect survey - use the filters in the view layer configuration so that the view only includes the points you'd like append to your other survey
2. Export the view layer to FGDB
3. Use the "Update data" option to add features to your correct survey using the FGDB you exported. Make sure you match all the fields so that all your data is carried across.
Hopefully that helps,
Issy
