Enable Option "Not to Add" geoprocessing result into map (TOC) after "Split by Attributes"
Are you aware you can control many aspects of how a tool interacts with the application through the Options dialogue?
The previous commenter is correct. You can uncheck the "Add output datasets to an open map" in the Geoprocessing Options dialogue.
https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/basics/geoprocessing-options.htm#ESRI_SECTION1_6A416689BC8046BCB25B6A0BAFCCA7CB
Sign in to post, follow content, and more. New here? Register for free.
