Please add a select all text, or select all elements in the layout. Also add an invert selection for all or for text or elements.
Hi! While ArcGIS Pro doesn't have a select all text option, there are a couple features currently in the application that may be helpful in your scenario. You can select all elements using the Select All button on the ribbon, or the Ctrl-A keyboard shortcut. Additionally, the List by Element Type tab on the Contents Pane allows you to see all the text elements grouped together. You can then quickly select them all in the pane.
Sign in to post, follow content, and more. New here? Register for free.
