I just updated to 3.3.0 and now a client is unable to view my geodatabase with ArcMap (v. 10.8.2), ArcGIS Pro (3.1.2) or ArcCatalog (10.8.2).Anyone else have this?
It is possible to upgrade enterprise and file geodatabases, though it would be to whatever Enterprise equivalent that Pro 3.3 is (looks like Enterprise 11.3). I would think a geodatabase created in 11.x will not work in ArcMap. If the geodatabase was not upgraded, I have had issues opening layers in ArcMap if you set up newer Pro-related functionality (attribute rules, for instance). Once you remove the advanced functionality then the layer works in ArcMap again.
This likely has to do with the new datetime high precision field type found here: High Precision Date Field Issue when Registering T... - Esri Community
I was referring specifically to enterprise geodatabases. Not sure about file geodatabases.
What kind of geodatabase can be upgraded in 3.3 (all geodatabases including file geodatabases or just enterprise geodatabases)?
When you upgraded, did you upgrade the geodatabase to a 3.3 database as well? Alternatively, is this a new geodatabase you created after you upgraded to 3.3?
