Hello, I am pretty new to Power Automate integration with Survey123 results.
The idea is to have a conditional trigger to add a row in an online excel table for survey repeats that answer 'yes' to a 'select_one yes_no' entry. When setting the condition within an 'Apply to Each' box the submission fails if a repeat is not given a value or a 'null' entry. These are not required sections of the survey and so they are sometimes left blank.
Hopefully this is a simple fix, but I am not sure what needs to be done to allow the flow to continue to the next section without failing. No excel entry is needed when the repeat is has no data.
Any guidance would be greatly appreciated!
