Good afternoon,
Is there a way to copy/paste a line from one layer that I am not editing to the layer I am editing?
Ther are moments when instead of drawing a line we could copy/paste another one that already exists in another layer.
As @AlixVezina mentioned in Copy Features for Experience Builder:Copy and Paste in now available in Experience Builder in ArcGIS Online. It will also be available in Enterprise 12.1 which is targeted for May 2026. You can find it in the Edit widget, when using "Interact with a Map widget" Mode. The option is at the bottom of the Content panel, as part of the Advanced editing tools.
Thank you @ericsamson_tract
I am recommending to use ArcGIS Pro. Editors will drag and drop the editable web map from AGOL to ArcGIS Pro, then they will digitize lines copy/pasting them from another background layer.
This used to be possible with the smart editor within web appbuilder, but was not ported over. I need this as well. Right now I think the only option is creating a custom widget.
Tahnk you @Laura
Do not believe the widget in EXB is equipped to handle much like that.
https://learn.arcgis.com/en/projects/copy-features-between-layers/
https://support.esri.com/en-us/knowledge-base/how-to-copy-specific-line-features-and-paste-them-to-an-000027203
