I am following the instructions on this link: Edit widget—Web AppBuilder for ArcGIS | ArcGIS
When I open my app I don't see a pencil icon next to the related table that I should see in instruction 1 (d). I have a right arrow that only allows me to see the related record and then edit it. There aren't any options to add a related record. Is there something I am missing?
This still seems to be an issue in Portal 11.1 if you are using a 1 to 1 relationship from a feature class to a table. Has anyone had any success with this?
Ryan:
Do you have any idea how this issue was resolved? Did you make any changes on your side? Or was there an AGOL update that fixed the issue?
Is this available in portal yet? We are currently running 10.6
Not sure about portal or server but I have it working in AGOL using the edit widget. My sign inventory and inspections tables now show a plus sign and I can add related records.
Is there any update on this?
This seems to be an existing Bug: https://my.esri.com/#/support/bugs/BUG-000105597
No "+" button is visible in the Edit Widget section for related records. As OP states, only able to edit or view existing related records.
Using 10.5 ArcGIS Server Enterprise with 10.5 Portal. Not using hosted services via Data Store, just normal feature services published to ArcGIS Server.
If we can add a related record in Collector, it should not be that difficult in the Web App.
This case was Escalated and hope we get Esri Inc to come up with a hot fix of some sort.
They are the settings for the feature layer. Is that just for the parent data? I attached a screenshot of where I go to see the settings.
Ryan,
Is that for the parent data or the related data?
I believe so. Here are the settings.
Is your related data published as a FeatureServer service and does it allow for edits?
