In which files do I have to update the serviceURL for my app's Print widget? I updated it in config_Print.json, but my app is still recognizing the old print service I had registered. I want to change it back to the default AGOL print service: Task: Export Web Map Task
Ben,
Which WAB are you using? The online, the Developer version? If you are using the developer version make sure you are changing the config_Print.json in the correct apps folder.
Using WAB beta 3, developer version. I downloaded my app and am hosting it in a different folder other than the default arcgis-web-appbuilder-1.0beta3 developer folder.
So are you saying that you changed the print service url in the print-config.json in that downloaded apps folder and that app is still using the old url?
Yes. But it's working now for some reason. I don't understand why it wasn't instantaneous. It didn't work the first time because I was getting the error below, which I'm assuming meant the app was still recognizing the old service url blacked-out below. This error no longer pops-up so I take that it's using the default AGOL print service url that I set it to.
