Hi
We are still looking into this, in the meantime I attach a 10.2.2 Toolbox with ACAD reader and writer, you can update the reader and writer after copying into your own tools, then they can point to your own data.
Regards
Dear Bruce,
Thank you for the response. ACAD format is not available in the format gallery as it used to be in earlier versions. The issue I am facing is in fact with the Spatial ETL tool where I am unable to find the ACAD format.
Rouf
Hello
We are chasing an issue in 10.2.2 whereby the ACAD format is unavailable in the Quick tools, but is available in the format gallery for Spatial ETL tools. The issue is not reliably reproducable.
In the meantime please use a Spatial ETL tool for data import and export.
Dear All,
I am facing the same issue. Perhaps I can find a different format "Esri Mapping Specification for CAD (MSC)". But, it is not equivalent to ACAD like it doesn't allow the user to export the attributes as xdata.
Request some one from ESRI to respond to this issue.
something is amiss then since the interoperability extension states that ACAD is supported perhaps it is now called something different in ArcMap 10.2.2
Hi Greg,
Thanks for your reply! I will give it a try.
Wijmke
Hey Wijmke,
Nope. We could not get it to show up at all in 10.2.2. The only solution I found was to uninstall 10.2.2 and reinstall 10.2.1. Let me know if you come across anything.
Thanks!
Hello Greg,
Have you already found a solution to the problem. I have exactly the same problem..
HiI can see ACAD in my 10.2.2 Data Interoperability install when working in Workbench.Interoperability Connections work too.Something may have clobbered the format resources files, perhaps try a clean install.Regards
