i have downloaded global LU and LC map in ESRI format but i am not being able to open it in Arc Gis desktop
The .adf files are components of a coverage, navigate the directory above the .adf files with the Catalog window in ArcGIS for Desktop to see the data.
I nevigated the directory above the file, but it shows empty in the catalog
window
Please check your data are intact, it should be in this structure:
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
this file is probably in esri grid format. Be sure have both the dataset and info folders. Catalog will only recognize data that is in the proper structure to be read; to see what's actually in the folder you need to use Windows Explorer.
ArcGIS Help (10.2, 10.2.1, and 10.2.2): Esri Grid format
workspace_folder \ mygrid \ xyz.adf prj.adf ... \ info \ arc.dr9 xyz.dat xyz.nit ...
