Hi All,
We currently have a configuration for AGP that works against AGP 3.1 and 3.2. 3.3 was just released and we've verified that it works as well (without rebuilding).
I understand that AGP 3.3 is built against NET8. At the moment, we cannot upgrade to target against net8 in order to continue support for 3.1 and 3.2 (upgrading makes them incompatible). We are currently referencing the AGP 3.1 NuGet package.
The problem is with debugging. If we build our configuration project, the proConfigX file is *not* copied to Documents\ArcGIS\AddIns\ArcGISPro\Configurations. This works if I have AGP 3.2 installed.
I'll repeat that - when I build with AGP 3.2 installed, the proConfigX file is copied. If I have AGP 3.3 installed, it is *not* copied.
If the file is not located in that folder, then our configuration does not load and base AGP loads instead. If I copy the file into the folder that was built against AGP 3.2, then the configuration loads. As long as the correct proConfigX file is located there then our configuration loads. I cannot find the proConfigX file that is built when building against AGP 3.3.
This is very frustrating because side-by-side installation is not supported by AGP. It is either 3.2 or 3.3, not both.
Can someone please look into this and confirm that it is a regression? Make sure your configuration (I suspect an add-in has the same issue) is targeting net6 and using the AGP 3.1 NuGet package.
If you have any questions or need more clarification, please let me know.
Kris
