Hi Robert,For some people, the Set Flow Direction button on the Utility Network Analyst toolbar doesn't suffice, as their geometric network contains loops and/or they have conflicting sources/sinks. In this case, they need to set flow direction using another tool. The simplest tool is to set flow by digitized direction, in which case, they need to have the digitized direction aligned with the flow direction they desire.If, however, setting flow direction using the button on the Utility Network Analyst toolbar works fine for setting the flow for your own geometric network, then you don't need to worry about the digitized direction of the lines.Alan
