I'm using ArcGIS Pro 3.0.3 (UN schema version 3, untools version 3.0.0). Apply Asset Package changes my Float data type fields to Double data type in the output enterprise geodatabase.
Is this a known bug? Is there any way to prevent this conversion? Was it fixed in 3.1 or later? I don't understand why this happens if Float is a valid data type in EGDBs, too. Why can't it be retained? If asset packages cannot handle Float then that means I change my entire workflow and create all of them directly in the EGDB...which makes for a very inconvenient deployment preparation. Not only that, if you were to export the EGDB to asset package and bring it back in, you'd have to re-create all your fields again? ...or just accept Double 38 precision, 8 scale, instead of Float which is not ideal if you want to limit numbers, have smaller decimal places and save a little data storage.
