<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/claroGrid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> var findTask, findParams; var map, center, zoom; var grid, store; var textLayer; require([ "esri/map", "esri/graphic", "esri/layers/GraphicsLayer", "esri/tasks/FindTask", "esri/tasks/FindParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "dijit/form/ToggleButton", "esri/Color", "dojo/on", "dojo/dom", "dijit/registry", "dojo/_base/array", "dojo/_base/connect", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore", "dijit/form/Button", "dojo/parser", "dojo/_base/array", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, Graphic, GraphicsLayer, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Font, TextSymbol, ToggleButton, Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser, array ) { parser.parse(); registry.byId("search").on("click", doFind); //registry.byId("showLabels").on("click", doShowLabels); center = [-83.266, 42.568]; zoom = 4; map = new Map("map", { basemap: "gray", center: center, zoom: zoom }); //Create Find Task using the URL of the map service to search findTask = new FindTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/"); map.on("load", function () { //Create the find parameters findParams = new FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["areaname","st","pop2000"]; findParams.outSpatialReference = map.spatialReference; }); function doFind() { //Set the search text to the value in the box findParams.searchText = dom.byId("cityName").value; findTask.execute(findParams, showResults); } function doShowLabels(){ findParams.searchText = dom.byId("cityName").value; findTask.execute(findParams, showLabels); } function showResults(results) { map.graphics.clear(); var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL, new Color([255, 0, 0, 1]), 1), new Color([255, 0, 0, 1]) ); //create array of attributes var items = arrayUtils.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); return result.feature.attributes; }); //Create data object to be used in store var data = { identifier : "OBJECTID", //This field needs to have unique values label : "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items : items }; //Create data store and bind to grid. store = new ItemFileReadStore({ data : data }); var grid = registry.byId("grid"); grid.setStore(store); grid.on("rowclick", onRowClickHandler); //Zoom back to the initial map extent map.centerAndZoom(center, zoom); } function showLabels(results){ var items = arrayUtils.map(results, function (result) { var geom = result.feature.geometry; var displayText = result.feature.attributes.AREANAME; var font = new Font( "16pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica" ); var textSymbol = new TextSymbol( displayText, font, new Color("#DC143C") ); textSymbol.setOffset(0,18); textLayer = new GraphicsLayer(); textLayer.add(new Graphic(geom, textSymbol)); map.addLayer(textLayer); //map.graphics.add(new Graphic(geom, textSymbol)); }); } //Zoom to the parcel when the user clicks a row function onRowClickHandler(evt) { var clickedCityName = evt.grid.getItem(evt.rowIndex).OBJECTID; var selectedCityName = arrayUtils.filter(map.graphics.graphics, function(graphic) { return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedCityName); }); if (selectedCityName.length) { var center = [selectedCityName[0].geometry.getLongitude(), selectedCityName[0].geometry.getLatitude()]; var zoom = 15; map.centerAndZoom(center, zoom); } } new ToggleButton({ showLabel: true, onChange: function(val){ if(val == true){ findTask.execute(findParams, showLabels); this.set('label', 'Hide Labels'); } else{ textLayer.clear(); this.set('label', 'Show Labels'); } }, label: "Show Labels" }, "showLabels"); }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;"> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;"> City: <input type="text" id="cityName" size="60" value="Redlands" /> <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search </button> <button id="showLabels"></button> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;"> <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'"> <thead> <tr> <th field="OBJECTID">ObjectID</th> <th field="AREANAME">City</th> <th field="ST" >State</th> <th field="POP2000">Population</th> </tr> </thead> </table> </div> </div> </body> </html>
Another way you can do this is by adding a text symbol to a graphic. Below is an example:
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/dojo/dojox/grid/resources/claroGrid.css"> <link rel="stylesheet" href="http://js.arcgis.com/3.9/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script src="http://js.arcgis.com/3.9/"></script> <script> require([ "esri/map", "esri/graphic", "esri/tasks/FindTask", "esri/tasks/FindParameters", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/Font", "esri/symbols/TextSymbol", "esri/Color", "dojo/on", "dojo/dom", "dijit/registry", "dojo/_base/array", "dojo/_base/connect", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore", "dijit/form/Button", "dojo/parser", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, Graphic, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Font, TextSymbol, Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser ) { var findTask, findParams; var map, center, zoom; var grid, store; var labels = []; parser.parse(); registry.byId("search").on("click", doFind); registry.byId("showLabels").on("click", doShowLabels); center = [-83.266, 42.568]; zoom = 4; map = new esri.Map("map", { basemap: "gray", center: center, zoom: zoom }); //Create Find Task using the URL of the map service to search findTask = new FindTask("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/"); map.on("load", function () { //Create the find parameters findParams = new FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = ["areaname","st","pop2000"]; findParams.outSpatialReference = map.spatialReference; }); function doFind() { //Set the search text to the value in the box findParams.searchText = dom.byId("cityName").value; findTask.execute(findParams, showResults); } function doShowLabels(){ findParams.searchText = dom.byId("cityName").value; findTask.execute(findParams, showLabels); } function showResults(results) { map.graphics.clear(); var symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 15, new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL, new Color([255, 0, 0, 1]), 1), new Color([255, 0, 0, 1]) ); //create array of attributes var items = arrayUtils.map(results, function (result) { var graphic = result.feature; graphic.setSymbol(symbol); map.graphics.add(graphic); return result.feature.attributes; }); //Create data object to be used in store var data = { identifier : "OBJECTID", //This field needs to have unique values label : "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items : items }; //Create data store and bind to grid. store = new ItemFileReadStore({ data : data }); var grid = registry.byId("grid"); grid.setStore(store); grid.on("rowclick", onRowClickHandler); //Zoom back to the initial map extent map.centerAndZoom(center, zoom); } function showLabels(results){ var items = arrayUtils.map(results, function (result) { var geom = result.feature.geometry; var displayText = result.feature.attributes.AREANAME; var font = new Font( "16pt", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica" ); var textSymbol = new TextSymbol( displayText, font, new Color("#DC143C") ); textSymbol.setOffset(0,18); map.graphics.add(new Graphic(geom, textSymbol)); //return result.feature.attributes; }); } //Zoom to the parcel when the user clicks a row function onRowClickHandler(evt) { var clickedCityName = evt.grid.getItem(evt.rowIndex).OBJECTID; var selectedCityName = arrayUtils.filter(map.graphics.graphics, function(graphic) { return ((graphic.attributes) && graphic.attributes.OBJECTID === clickedCityName); }); if (selectedCityName.length) { var center = [selectedCityName[0].geometry.getLongitude(), selectedCityName[0].geometry.getLatitude()]; var zoom = 15; map.centerAndZoom(center, zoom); } } }); </script> </head> <body class="claro"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;"> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="height:40px;"> City: <input type="text" id="cityName" size="60" value="Philadelphia" /> <button id="search" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Search </button> <button id="showLabels" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button" >Show Labels </button> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit/layout/ContentPane" style="border:1px solid #000;"></div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom'" style="height:150px;"> <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'"> <thead> <tr> <th field="OBJECTID">ObjectID</th> <th field="AREANAME">City</th> <th field="ST" >State</th> <th field="POP2000">Population</th> </tr> </thead> </table> </div> </div> </body> </html>
