I have a series of points with label rotation information. When I set the "Rotation Field" value to "None" I can adjust the placement of the label to left, right, top, bottom, etc.
However when I set my rotation field, the labels move above the points stay there regardless of what I set my placement to. The only one that does make a different is "Centre on Point", which does as you would expect.
Is there some way I can move my rotated labels below the points?
