Arcade expressions currently are not supported for Heat Maps.
To use Arcade expression with the Heat Map symbology style on ArcGIS Online.
So, I do not need to add a permanent field within the dataset.
Heatmap is using feature density with kernel proximity method which does not leverage a field.
https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-HeatmapRenderer.html
Sign in to post, follow content, and more. New here? Register for free.
