Been trying to publish a web map from an ArcGIS Pro project with dozens of layers in multiple groups that keeps failing after hours of waiting for it to publish. Every feature class has been moved into one geodatabase with everything in one feature dataset with Web Mercator coordinate system. It's all vector data, no rasters.
2024-04-29 10:32:46 Status: InProgress StatusMessage: Successfully wrote sharing info file
2024-04-29 10:32:46 Status: InProgress StatusMessage: Creating thumbnail from map
2024-04-29 10:32:47 Status: Pending StatusMessage: Sharing process started
2024-04-29 10:32:47 Status: InProgress StatusMessage: Sharing process started
2024-04-29 10:32:48 Status: InProgress StatusMessage: Reading thumbnail from file
2024-04-29 10:32:48 Status: InProgress StatusMessage: Sharing process started
2024-04-29 10:32:52 Status: InProgress StatusMessage: Extracting all manifests from the configuration of the web map/scene
2024-04-29 10:32:52 Status: InProgress StatusMessage: Publishing individual web layers
2024-04-29 10:32:52 Status: InProgress StatusMessage: Creating the type keywords for the web map/scene
2024-04-29 10:32:54 Status: InProgress StatusMessage: Extracting all manifests from the configuration of the web map/scene
2024-04-29 10:32:56 Status: InProgress StatusMessage: Loading manifest
2024-04-29 10:32:56 Status: InProgress StatusMessage: Reading thumbnail from file
2024-04-29 10:32:56 Status: InProgress StatusMessage: Publishing process started
2024-04-29 10:32:56 Status: InProgress StatusMessage: Consolidating data and staging web layer
2024-04-29 10:33:06 Status: InProgress StatusMessage: Using ArcGIS Version 13.2 for staging (Source for version: GP Staging Parameters)
2024-04-29 10:33:06 Status: InProgress StatusMessage: Stage Tool initialized
2024-04-29 10:33:06 Status: InProgress StatusMessage: Preparing maps and layers for processing
2024-04-29 10:33:07 Status: InProgress StatusMessage: Consolidate data
2024-04-29 10:33:07 Status: InProgress StatusMessage: Staging feature service
2024-04-29 10:34:44 Status: InProgress StatusMessage: Compressing package into SD file
2024-04-29 10:37:20 Status: InProgress StatusMessage: Staging successful
2024-04-29 10:37:20 Status: InProgress StatusMessage: Uploading service definition
2024-04-29 10:37:20 Status: InProgress StatusMessage: Publishing tool initialized
2024-04-29 10:37:20 Status: InProgress StatusMessage: Publishing web layer (AGO)
2024-04-30 01:27:56 Status: InProgress StatusMessage: Publishing web layer failed (AGO)
2024-04-30 01:27:58 Status: InProgress StatusMessage: Publishing tool execution failed
2024-04-30 01:28:12 Status: Failed ErrorMessage: Failed to publish web layer
2024-04-30 01:28:14 Status: Failed ErrorMessage: Failed to publish web layer NAME_WFL1.
2024-04-30 01:28:16 Status: Failed ErrorMessage: Failed to publish one or more web layers
