Hello, i need a multiselect with a search functionality just like the one used in the Filter widget in Experience builder, i cannot find what i'm looking for in jimu-ui.
Can someone help ?
@JanSarata You are referring to https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-advanced-select-component/m-p/1401266#M11783, right? We will note that and see if we can implement it.
@WalaZargouni The AdvancedSelect component is what you are looking for.
The onChange={function noRefCheck(){}} function does not do anything. You will need to write your own onChange function to handle the click event as needed.
Yes apparently the AdvancedSelect is what i need, the dynamic data example code is not available in the storybook, i tried implementing it as the following
Hi @TonghuiMing, as far as I know, The AdvancedSelect is still missing the method onSearchInputChanged which is really important while using with API calls as @WalaZargouni mentioned. Are there any plans to implement this method? https://developers.arcgis.com/experience-builder/storybook/?path=/story/components-jimu-ui-index-advancedselect--dynamic-data
It looks like the FieldSelector component yes, but with the FieldSelector it works only with a datasource and its fields. i need to load the items of the select with an api call
I think you are talking about FieldSelector.
https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-advanced-data-source-selector-fieldselector--docs
Take a look in the advanced folder of the Storybook to see if you find what you want. There are several similar options.
