I am using EXB dev edition version 1.12 which is currently pointing to the JS API version 4.27.
I would like to refer to the latest version 4.29 instead.
How can I achieve this?
Did you run npm ci in the server and client folders?
https://developers.arcgis.com/experience-builder/guide/release-versions/
Each version of Experience Builder is built on the next version of the Javascript API. Upgrade to 1.14 and you will be using 4.29 of the API.
Hi @JeffreyThompson2
I tried the upgrade approach, I copied the app folder from 1.12 to 1.14. But the app I am working with contains custom widgets built with version 1.12. I am getting the issues below
I did run npm ci at /client and /server folders during the initial installation of version 1.14. But after I pasted my app folder from version 1.12, I did not run the command.It is working now after running the command again.
Thanks, that solved my issue.
