I am trying to convert Waze Jams coordinates into something usable in velocity. There is a helpful blog herehttps://community.esri.com/t5/arcgis-velocity-questions/create-line-geom-from-coords/m-p/1226887#M101but the issue is when I add the arcade expression in the calculate field tool within velocity, I cannot click OK to exit out of the tool. Is the calculate field tool the best option or has anyone found a better way to convert the line attribute from Waze Jams into something visual?
After contacting ESRI Support, they came up with this workflow which worked, the Waze lines are now showing up on my map. This is a great work around until Velocity 5.2 comes out.
Thanks to ESRI for their support!
@NateRogers1 Thanks for reaching out - without any images or additional info I would suggest that you log a support case with Esri Support Services. You can also email me at pnasuti@esri.com and I can get myself or another team member to help you resolve the issue you are facing.
We are working to try and add a "Waze" feed type for the Velocity 5.2 release which would handle all this automatically and configure geometry for the users. Stay tuned for more updates on that closer to early June.
