Hello everybody!
If I have a file geodatabase created in ArcGIS Pro 3.2 (version 10), and I want to converted to an older version 10.4 in ArcMap.. Is it possible ?
The version for file geodatabases has not changed since 10.1, which is version 10, like you mentioned.
Client and geodatabase compatibility
The version for file geodatabases has not changed since 10.1. The version for mobile geodatabases has not changed since ArcGIS Pro 2.7.
However, if you need to create an older version of File geodatabase like 9.3, or 9.2, you can use the 'Create File Geodatabase' tool and select the required version in the 'File Geodatabase Version' parameter of the tool.
Creating an earlier version of a file or personal geodatabase
like I mean our client does not use ArcGIS Pro, they use ArcMap 10.4 ! that's why our Gdb file that created in ArcGIS pro not open for them in ArcMap 10.4... they ask me to converted to ArcMap 10.4 version so they can open the file.. you got my point?
What is stored in the File Geodatabase? They can't access anything or only some of the data? What is the error message encountered?
its a water data actually.. no it's not open for them
if I got a ArcMap, then there is a way to convert the file to older version ? steps or anything
