I have a strange problem when using python code to overwrite a feature service on our ArcGIS Online account. I created two point feature layers (fire hydrants data), one is for the fire department and another version with some fields removed (not visible) for the public. I can manually upload and/or share each feature layer to ArcGIS Online and even overwrite the feature services. The data looks fine and I can create webmaps with no problems. I then used Python code that we found on ESRI’s website to upload the feature layers. Below is a link to the discussion of the code that we use with no problems in other project for a few years now.
https://community.esri.com/t5/python-questions/automate-overwrite-web-layer-feature-class/td-p/20067
The problem I’m having is after the automated Python code runs overnight, the attribute table for the “fire department” version is missing data. See the attached screen shot. The “public” version feature service attribute table’s data is visible. When I select Visualization option for the “fire department” feature layer (hosted), I do see points on a map but no data when I select a point. If I re-run the manual overwrite option within the ArcGIS Pro project, it corrects the problem and I can see the data in the attribute table. Any suggestions on where to the look? I'm planning to add a field that was removed for the "public" table one at time and run the python code until I see a failure.
