Field Maps Version: 24.1.1 build 1059
I have an offline map with two polygons I created on ArcGIS online and configured the form in FieldMaps.
Each polygon contains equivalent fields and both are sync enabled.
The map is downloaded on my iPhone. I create two offline polygons (one each).
One of the polygons sync, the other sync fails with the error: Null Pointer.
Logs:
4/10/24, 3:53 PM [788a33ce-d47b-43a3-923c-d05aae3e884a] - Layer: (Violet Plot) Error: Error Domain=com.esri.arcgis.runtime.error Code=1 "Null pointer." UserInfo={NSLocalizedFailureReason=, NSLocalizedDescription=Null pointer., Additional Message=}
4/10/24, 3:53 PM [788a33ce-d47b-43a3-923c-d05aae3e884a] - Message 18/21: Layer result: Sync failed. Name: Violet Plot, LayerID: 0, TableName: violet_plot, URL: https://services1.arcgis.com/gGHDlz6USftL5Pau/arcgis/rest/services/violet_plot/FeatureServer/0 Job error 1 Null pointer.
Home
