We are implementing Time slider programmaticaly (for the reasons we cannot customize the standard one according to requirements).
app.currentTimeSeriesLayer = initialised earlier and added to map// visible on the map
function MyTimeSliderRun()
var timeIntervalMilliSeconds = 5000;
var startYear = 1995;
var endYear = 2016;
var Years = endYear - startYear;
var increment = 0;
for (i = 0; i <= Years; i++) {
setTimeout(function () {
var layerDefinitionsTS = [];
app.currentTimeSeriesLayer.setLayerDefinitions(null, true);
var curYear = startYear + increment;
increment = increment + 1;
layerDefinitionsTS[app.currentTimeSeriesLayer.visibleLayers[0]] = "Year = " + curYear;
app.currentTimeSeriesLayer.setLayerDefinitions(layerDefinitionsTS, false);
}, timeIntervalMilliSeconds*i);
We cannot see the layer on the map, what is a possible reason?
Code in SandBox
<!DOCTYPE html>
<html>
<head>
<title>Well completion dates for the Hugoton Gas Field Over Time</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.18/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.18/esri/css/esri.css">
<style>
html, body, #mapDiv {
padding:0;
margin:0;
height:100%;
#mapDiv {
position: relative;
#bottomPanel {
left: 50%;
margin: 0 auto;
margin-left: -500px;
position: absolute;
bottom: 2.5em;
#timeInfo{
border-radius: 4px;
border: solid 2px #ccc;
background-color: #fff;
display: block;
padding: 5px;
position: relative;
text-align: center;
width: 1000px;
z-index: 99;
</style>
<script src="https://js.arcgis.com/3.18/"></script>
<script>
var map;
require([
"esri/map", "esri/layers/ArcGISDynamicMapServiceLayer",
"esri/TimeExtent", "esri/dijit/TimeSlider",
"dojo/_base/array", "dojo/dom", "dojo/domReady!"
], function(
Map, ArcGISDynamicMapServiceLayer,
TimeExtent, TimeSlider,
arrayUtils, dom
map = new Map("mapDiv", {
basemap: "streets",
center: [-101.15, 37.604],
zoom: 9
//https://developers.arcgis.com/javascript/3/sandbox/sandbox.html?sample=time_sliderwithdynamiclayer
var opLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSWells/MapServer");
opLayer.setVisibleLayers([0]);
//apply a definition expression so only some features are shown
var layerDefinitions = [];
layerDefinitions[0] = "FIELD_KID=1000148164";
opLayer.setLayerDefinitions(layerDefinitions);
//add the gas fields layer to the map
map.addLayers([opLayer]);
map.on("layers-add-result", MyRunTimeSeries);
var currentTimeSeriesLayer = opLayer;
function MyRunTimeSeries()
var timeIntervalMilliSeconds = 10000;
var endYear = 2016;
var increment = 0;
currentTimeSeriesLayer.setDisableClientCaching(true);
if (increment == 0)
layerDefinitionsTS[currentTimeSeriesLayer.visibleLayers[0]] = "COUNTY_COD = " + 7;
if (increment == 1)
layerDefinitionsTS[currentTimeSeriesLayer.visibleLayers[0]] = "COUNTY_COD = " + 9;
if (increment == 2)
layerDefinitionsTS[currentTimeSeriesLayer.visibleLayers[0]] = "COUNTY_COD = " + 125;
if (increment == 3)
layerDefinitionsTS[currentTimeSeriesLayer.visibleLayers[0]] = "COUNTY_COD = " + 135;
if (increment > 3)
{currentTimeSeriesLayer.setLayerDefinitions(null, false);}
else {
currentTimeSeriesLayer.refresh();
console.log("increment: "+increment)
console.log("layerDefinitionsTS: "+layerDefinitionsTS);
console.log(currentTimeSeriesLayer.layerDefinitions);
console.log(map);
console.log(map.layerIDs);
//map.on("layers-add-result", initSlider);
function initSlider() {
var timeSlider = new TimeSlider({
style: "width: 100%;"
}, dom.byId("timeSliderDiv"));
map.setTimeSlider(timeSlider);
var timeExtent = new TimeExtent();
timeExtent.startTime = new Date("1/1/1921 UTC");
timeExtent.endTime = new Date("12/31/2009 UTC");
timeSlider.setThumbCount(2);
timeSlider.createTimeStopsByTimeInterval(timeExtent, 2, "esriTimeUnitsYears");
timeSlider.setThumbIndexes([0,1]);
timeSlider.setThumbMovingRate(2000);
timeSlider.startup();
//add labels for every other time stop
var labels = arrayUtils.map(timeSlider.timeStops, function(timeStop, i) {
if ( i % 2 === 0 ) {
return timeStop.getUTCFullYear();
} else {
return "";
timeSlider.setLabels(labels);
timeSlider.on("time-extent-change", function(evt) {
var startValString = evt.startTime.getUTCFullYear();
var endValString = evt.endTime.getUTCFullYear();
dom.byId("daterange").innerHTML = "<i>" + startValString + " and " + endValString + "<\/i>";
</script>
</head>
<body class="claro">
<div id="mapDiv">
<div id="bottomPanel">
<div id="timeInfo">
<div>Hugoton Gas Field Wells from <span id="daterange">1921 to 2009</span> (Completion date)</div>
<div id="timeSliderDiv"></div>
</div>
</div>
</div>
</body>
</html>
