Hi, I'm trying to modify the Access features with pointer events sample code from the ArcGIS Developers site. I want it to work with an existing webmap and with a polygon layer instead of a line. I've run the code through ChapGPT, which had me make some changes from the original structure, but the code isn't working either way. (Feature layer url and portal item id have been removed from the code below, but both do load in codepen.)
Any help would be much appreciated.
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Access features with pointer events | RH Planning Areas</title>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
#info {
background-color: black;
opacity: 0.75;
color: lightBlue;
font-size: 18pt;
padding: 8px;
visibility: hidden;
</style>
<link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.29/"></script>
<script>
require(["esri/WebMap", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/symbols/SimpleFillSymbol"],
(WebMap, MapView, FeatureLayer, SimpleFillSymbol) => {
const PlanningAreasLayer = new FeatureLayer({
url: "https://.../FeatureServer/0",
outFields: ["*"]
const webmap = new WebMap({
portalItem: {
portal: "https://www.arcgis.com",
layers: [PlanningAreasLayer]
const view = new MapView({
container: "viewDiv",
map: webmap,
center: [-83.1563078,42.6645259],
zoom: 12,
highlightOptions: {
color: "lightBlue"
view.ui.add("info", "top-right");
view
.when()
.then(() => {
return PlanningAreasLayer.when();
.then((layer) => {
const renderer = layer.renderer.clone();
const fillSymbol = {
type: "simple-fill",
color: [255, 0, 255, 0], //transparent fill
outline: {
color: [255, 0, 0, 0], //red
width: 4
renderer.symbol = fillSymbol;
layer.renderer = renderer;
// Set up an event handler for pointer-down (mobile)
// and pointer-move events (mouse)
// and retrieve the screen x, y coordinates
return view.whenLayerView(layer);
.then((layerView) => {
view.on("pointer-move", eventHandler);
view.on("pointer-down", eventHandler);
function eventHandler(event) {
// only include graphics from PlanningAreasLayer in the hitTest
const opts = {
include: PlanningAreasLayer
// the hitTest() checks to see if any graphics from the PlanningAreasLayer
// intersect the x, y coordinates of the pointer
view.hitTest(event, opts).then(getGraphics);
let highlight, currentName;
function getGraphics(response) {
// the topmost graphic from the PlanningAreasLayer
// and display select attribute values from the
// graphic to the user
if (response.results.length) {
const graphic = response.results[0].graphic;
const attributes = graphic.attributes;
const areaName = attributes.Neighbor_1;
const mapLink = attributes.Neighborho
const id = attributes.OBJECTID;
if (highlight && currentName !== areaName) {
//Check if a highlight exists (is not null or undefined)
//Checks if the current name is not equal to the name
//If true, name has changed so highlight should be removed
//If condition is true, execute the following code
highlight.remove(); //Remove the highlight from the graphic
highlight = null; //Set the highlight variable to null
return; //Exit the current function
if (highlight) {
const query = layerView.createQuery();
query.where = "NAME = '" + areaName + "'";
layerView.queryObjectIds(query).then((ids) => {
if (highlight) {
highlight.remove()
highlight = layerView.highlight(ids);
currentName = areaName;
//diplay information about the feature
document.getElementById("info").style.visibility = "visible";
document.getElementById("name").innerHTML = areaName;
document.getElementById("link").innerHTML = mapLink;
} else {
// remove the highlight if no features are
// returned from the hitTest
if (highlight){
highlight.remove();
highlight = null;
document.getElementById("info").style.visibility = "hidden";
</script>
</head>
<body>
<div id="viewDiv"></div>
<div id="info">
<span id="name"></span> <br />
<span id="link"></span>
</div>
</body>
</html>
