is it possible to hide the scale bar on the map through the api,I didn't see any option on the map ...
Otherwise I have to go through the dom to hide it?
Thanks for your help
Hi @LionelGOUBET ,
Somewhere in your app you are likely adding the scalebar. It's not included by default. Find where you are adding the scalebar and simply remove that part from your code.
Or, if you want to be able to hide it and show it again use the scalebar.hide and show methods.
https://developers.arcgis.com/javascript/3/jsapi/scalebar-amd.html
var scalebar = new Scalebar({ map: map, attachTo: "top-right" });
all my excuses, I did not have this code in my all app ...
Thanks you very much ... sorry again
