I am having problems decoding the barcode in Arcgis Survey123 Connect, is there a solution to my problem, how do I decode the encoded barcode? or should I use a script?
Hello @HanggarPrasetio1,
Survey123 will only return the value from the barcode and won't do any decoding itself. You can use a custom JavaScript function to decode the barcode value and parse it as you need.
