Enterprise 11.1, Pro 3.2, Utility Network version 6.
Hi All,
I was recently trying to update a subnetwork in my deployment between two electrical substations. This subnetwork needs to be able to reverse direction to be fed from one substation or the other at either of its ends. At one end I created the subnetwork controller device which is closed for its normal state and at the other end I created another subnetwork controller and left the device open. I gave that subnetwork controller a different name. My assumption was that leaving the device open would prevent the subnetwork controller from being associated with the line and that the two subnetworks would currently have nothing to do with each other, as open points prevent traversability and define subnetworks for the rest of my deployment as designed. However, when updating the subnetwork, I got the following error:
I'm not sure why it would behave like this when the second subnetwork is a single open device. Does anyone have some insight?
