Since the enhancement of using arcade within quick capture to pull the nearest feature came out, we have used it several times. We have looked at the new dynamic choice list but that seems to only be for when the solution is first opened, not after each capture. In the electric industry when doing aerial patrols of the lines, typically there are multi lines or structures and if it was possible to populate a list based on the proximity to those features, we could accurately report defects via air and also select the correct line/structure if necessary after selecting a defect button to then associate it with the correct asset.
