Hi
How can I export selected feature in Layer to Shapefile in VB.NET
This is example how it can export in ArcGIS desktop
https://gis.stackexchange.com/questions/121057/arcmap-vb-net-export-map-to-shp-error
You can do it using geoprocessing Feature Class To Shapefile tool.
Geoprocessing API reference is here
I found the solutionis there any expert who can helpneed to be able to apply a filter from Layer and determine the file name that will be savedand know when Geoprocessing has finished processing
This is sample from RawMcGee which I found in the discussion
protected async Task<string> ConvertShp(string layerpath, string outpath) { if (!System.IO.Directory.Exists(outpath)) System.IO.Directory.CreateDirectory(outpath); var valueArray = await QueuedTask.Run(() => { //input layers list should contain the path of each layer name, i.e. if the root node is "Mapping" and the layer name is "gs_points", path is "Mapping\\gs_points". List<string> inlayers = new List<string>(); inlayers.Add(layerpath); //outpath is just the folder to save the shapefiles in return Geoprocessing.MakeValueArray(inlayers, outpath); }); // to let the GP tool run asynchronously without blocking the main thread // use the GPThread option of GPExecuteToolFlasgs // GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread; // instruct the tool run non-blocking GPThread IGPResult gpResult = await Geoprocessing.ExecuteToolAsync("FeatureClassToShapefile_conversion", valueArray, null, null, null, flags); return string.IsNullOrEmpty(gpResult.ReturnValue) ? $@"Error in gp tool: {gpResult.ErrorMessages}" : $@"Ok: {gpResult.ReturnValue}"; }
