<!-- reference ArcGIS JavaScript API --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.2"></script> <script type="text/javascript"> //require selection dijit dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.BorderContainer"); var map; var resizeTimer; function init() { esri.config.defaults.io.proxyUrl = "http://ourServer/proxy/proxy.ashx"; esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://ourServer/ArcGIS/rest/services/Geometry/GeometryServer"); var extent = new esri.geometry.Extent({"xmin":-13969147.281817337,"ymin":4805977.618327605,"xmax":-12669147.534885714,"ymax":6610095.663226462, "spatialReference":{"wkid":3857}}); map = new esri.Map("map",{extent:extent}); dojo.connect(map, "onLoad", function() { dojo.connect(dijit.byId('map'), 'resize', function() { resizeMap(); }); }); dojo.connect(map, "onLayersAddResult", initEditor); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://ourServer/ArcGIS/rest/services/BaseMap/MapServer"); map.addLayer(basemap); var evacuationPerimeter = new esri.layers.FeatureLayer("http://ourServer/ArcGIS/rest/services/MicroStorms_Collapsed/FeatureServer/1",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([evacuationPerimeter]); } function initEditor(results) { //build the layer and field information for the layer, display the description field //using a text area. var layers = dojo.map(results, function(result) { var fieldInfos= dojo.map(result.layer.fields,function(field){ if(field.name === 'description'){ return {'fieldName': field.name,'label':'Details',stringFieldOption:esri.dijit.AttributeInspector.STRING_FIELD_OPTION_TEXTAREA} } else{ return {'fieldName': field.name,'lable':field.alias} } }); return {featureLayer:result.layer,'fieldInfos':fieldInfos} }); var templateLayers = dojo.map(results,function(result){ return result.layer; }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, grouping: true, rows: 'auto', columns: 3 },'templateDiv'); templatePicker.startup(); var settings = { map: map, templatePicker:templatePicker, enableUndoRedo:true, layerInfos:layers, toolbarVisible: true, createOptions: { polygonDrawTools: [ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON, esri.dijit.editing.Editor.CREATE_TOOL_AUTOCOMPLETE] }, toolbarOptions: { reshapeVisible: true, cutVisible: true, mergeVisible: true } }; var params = {settings: settings}; var editorWidget = new esri.dijit.editing.Editor(params,'editorDiv'); editorWidget.startup(); map.infoWindow.resize(300,165); } //Handle resize of browser function resizeMap(){ clearTimeout(resizeTimer); resizeTimer = setTimeout(function(){ map.resize(); map.reposition(); }, 500); } dojo.addOnLoad(init); </script>
<script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
