import com.esri.ags.FeatureSet; import com.esri.ags.utils.GraphicUtil; private function zoomToButton_clickHandler(event:MouseEvent):void { var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var geometry:Geometry = graphic.geometry; var extent:Extent = geometry.extent; // returns null for MapPoint or Multipoint's with only one point if (graphic.attributes.hasOwnProperty("Road_Id") && graphic.attributes.hasOwnProperty("Monument_Z")){ var featLay:FeatureLayer = new FeatureLayer("http://myserver/ArcGIS/rest/services/myservice/MapServer/5"); featLay.useAMF = true; var query:Query = new Query(); query.outSpatialReference = map.spatialReference; query.where = "ID = " + graphic.attributes.Road_Id; query.returnGeometry = true; featLay.queryFeatures(query, new AsyncResponder(qResult, qFault)); function qResult(featureSet:FeatureSet, token:XMLList = null):void { try{ extent = GraphicUtil.getGraphicsExtent(featureSet.features); if (extent) { map.extent = extent; // make sure the whole extent is visible if (!map.extent.contains(extent)) { map.level--; } } else { var mapPoint:MapPoint; if (geometry is MapPoint) { mapPoint = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint:Multipoint = geometry as Multipoint; if (multipoint.points && multipoint.points.length > 0) { mapPoint = multipoint.points[0]; } } if (mapPoint) { // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint); } } } catch (error:Error){ trace(error.message); } } //on fault function qFault(info:Object, token:Object = null):void { trace(info.toString()); } }else{ if (extent) { map.extent = extent; // make sure the whole extent is visible if (!map.extent.contains(extent)) { map.level--; } } else { var mapPoint2:MapPoint; if (geometry is MapPoint) { mapPoint2 = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint2:Multipoint = geometry as Multipoint; if (multipoint2.points && multipoint2.points.length > 0) { mapPoint2 = multipoint2.points[0]; } } if (mapPoint2) { // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint2); } } } }
import com.esri.ags.tasks.supportClasses.Query; import mx.rpc.AsyncResponder;
private function zoomToButton_clickHandler(event:MouseEvent):void { var graphic:Graphic = hostComponent.graphic; var map:Map = hostComponent.map; var geometry:Geometry = graphic.geometry; var extent:Extent = geometry.extent; // returns null for MapPoint or Multipoint's with only one point //This if is used to make sure you are only doing this if it is the right layer //that is why we check for the existance of two different fields if (graphic.attributes.hasOwnProperty("Rt_num") && graphic.attributes.hasOwnProperty("TARGET_FID")){ var featLay:FeatureLayer = new FeatureLayer("http://maps.co.stearns.mn.us/ArcGIS/rest/services/Construction/MapServer/0"); featLay.useAMF = true; var query:Query = new Query(); query.outSpatialReference = map.spatialReference; //Your attribute is a string where mine was a number query.where = "Rt_num = '" + graphic.attributes.Rt_num + "'"; query.returnGeometry = true; featLay.queryFeatures(query, new AsyncResponder(qResult, qFault)); function qResult(featureSet:FeatureSet, token:XMLList = null):void { try{ extent = GraphicUtil.getGraphicsExtent(featureSet.features); if (extent) { map.extent = extent; // make sure the whole extent is visible if (!map.extent.contains(extent)) { map.level--; } } else { var mapPoint:MapPoint; if (geometry is MapPoint) { mapPoint = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint:Multipoint = geometry as Multipoint; if (multipoint.points && multipoint.points.length > 0) { mapPoint = multipoint.points[0]; } } if (mapPoint) { // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint); } } } catch (error:Error){ trace(error.message); } } //on fault function qFault(info:Object, token:Object = null):void { trace(info.toString()); } }else{ if (extent) { map.extent = extent; // make sure the whole extent is visible if (!map.extent.contains(extent)) { map.level--; } } else { var mapPoint2:MapPoint; if (geometry is MapPoint) { mapPoint2 = geometry as MapPoint; } else if (geometry is Multipoint) { var multipoint2:Multipoint = geometry as Multipoint; if (multipoint2.points && multipoint2.points.length > 0) { mapPoint2 = multipoint2.points[0]; } } if (mapPoint2) { // Zoom to 1/16th the size of the current extent. // This is the same as calling map.zoomIn() four times. map.zoom(1 / 16, mapPoint2); } } } }
