I am often viewing data at different locations and it makes things much cleaner looking and viewable with a specific map rotation at each location. Currently needing to right click on the map in the TOC and select Properties and then typing in the desired rotation for the location I am currently working with. Working with one or two locations isn't too bad but when I'm jumping around to a dozen of them it gets tedious and I have to have a separate file or printout of the desired rotations. My idea was to be able to set snap points on the Navigator so that when I jump to a location, I can easily grab the bezel and swing the map around to about where I want it and it will click right in.
