I am going to try and keep this simple.
I am pulling information from table A which has a text field with numbers like this 1119_232.2_93.2.
I get this information by using arcpy.da.Searchcursor._as_narray(). I then access the item from the array and save it as a string.
Then my script runs the calculate field tool which calculates a specific field based on the string.
I specifically send the numbers in as a string by using str()
However without fail every time it removes the "_" and write the numbers to the TEXT field as 1110232.293.2
parcels = "Parcels (Block and Lot) Data - For Internal Purposes Only - Do Not Distribute"
i = 0
cursor = arcpy.da.SearchCursor(Geocode, ["ObjectID"])
array = cursor._as_narray()
while i < len(array):
arcpy.management.SelectLayerByAttribute(Geocode, where_clause = "ObjectID = " + str(array[i][0]))
arcpy.management.SelectLayerByLocation(
in_layer="'Parcels (Block and Lot) Data - For Internal Purposes Only - Do Not Distribute'",
overlap_type="INTERSECT",
select_features="CSRR_PI_Coords_Geocoded",
search_distance=None,
selection_type="NEW_SELECTION",
invert_spatial_relationship="NOT_INVERT"
pcursor = arcpy.da.SearchCursor(parcels, ["Pams_Pin"])
parray = pcursor._as_narray()
string = str(parray[0][0])
splstr = string.split("_")
t = 1
concat = splstr[0]
if len(splstr) > 3:
while t < len(splstr) - 1:
concat += "_" + splstr[t]
t += 1
else:
while t < len(splstr):
t += 1
print(concat)
arcpy.management.CalculateField(
in_table=Geocode,
field = "USER_parcel_data",
expression = str(concat),
expression_type = "PYTHON3",
code_block = "",
field_type = "TEXT",
enforce_domains = "NO_ENFORCE_DOMAINS"
i += 1
I am about to save each spot in the array to its own field ie array[0] to Field A, array[1] to Field B, array[2] to Field C. then Calculate the field as FieldA + "_" + FieldB + "_" + FieldC
However that will add run time and I have this looping through 2500 features
