Hello
I am trying to creat a hot spot analysis map showing the fire pattern from MODIS fire data for the past 20 years. The figure 1 is the point distribution over the study area. I would like to perform a hot spot analysis to show where the hot spots, cold spots are. Therefore, I didn't assign any value for ''analysis field''.
I defined the projection to EPSG: 32637 in advance as well.
However, the result map only shows a big hot spot, without any other hot spots and cold spots while there is an obvious difference of the fire density between different parts of the study area.
Is it because there are too many points overlapping? Are there any recommended solutions to this?
Thank you in advance!
