in this page (database-requirements-oracle) there are some Oracle limitations on Oracle 19c.
Database requirements/limitations
In an Oracle multitenant architecture, you can create geodatabases in pluggable databases only.
Branch versioning is not supported in user-schema geodatabases.
The Oracle Text component must be installed. The Text component is installed by default in Oracle; however, if you did not perform a default installation, the Text component may not have been installed.
What does it mean "Branch versioning is not supported in user-schema geodatabases." exactly? Are there some limitation on deploy UN with branch versioning? How should the database be configured to accommodate the UN geodatabase on ESRI Enterprise suite 10.1 (on windows) + Oracle 19c (on Linux/Oracle Linux)?
thank you
